Clutch issue
  • Clutch issue
    pedal has a couple inches of play. when depressed to the floor there is a grinding noise. kinda like the feeling when you miss a shift and the synchros grind, but thats obviously not the issue here. no matter how far you push down it won't disengage the clutch.
    fluid level is good.
    any ideas?
    throwout bearing? i dunno i dont play with manuals
      whats it on? model and tranny etc? i know a bit about it.
        Throwout bearing is shot. I'm gonna go ahead and guess this just happened one day right?
          my title subtext said 98 xj 4.0 ax15
          it just happened somewhere between the ct line and my house
          was able to bang it into third and get down my road
            sounds like throw out bearing
              What happened was the bearing was fine, had a full pedal and everything. Then all of a sudden the bearing goes and that play at the top of the pedal is the extra clearance from the trashed bearing. Check your fluid, bet your out cause it all went to fill the slave cylinder.
                fluid level is good
                but ya
                  fluid level is good
                  but ya
                  Hurm, well it's your bearing. It's the best when it happens when the clutch is in, your sittin there and then the pedal just goes soft and the clutch is out
                    poppin tranny lines> poppin burrins
                      get a new jeep sam?
