B&M Megashifter
  • B&M Megashifter
    plus
    possible?
    info?
    2004 WJ
    4.0 - Bored TB - Super 44 with 3" side dump
    6.5" Front and Rear Long-armed, rear 44a, 4.56's
    not worth the trouble... IMO
      explain you must
      2004 WJ
        Because the AW4 uses a tcu and electronics to shift, so the ratchet action wouldn't do shit unless you built the tranny with a manual valvebody, which i don't even know if you can do (mostly cause i never bothered looking around to see if anyone makes one). If you want to have some control over your tranny, build a shifter like CSaddict did : http://sisoffroad.com/forums/showthread.php?t=231
          ahh thanks dude..
          that seems a bit complicated for me to manage at the moment.. maybe in a few months lol
          2004 WJ
            contact cs and have him build you one
              The wiring is actually very easy. I can help you along with it if you need help.
                it is not the aw4 its either the 42re or the 44re but it i had mine setup where you could manually shift it when i finished rebuilding it and forgot to reconnect the shift solenoids.
                  still cs's shifter kicks the b&m's shifters ass
                    it's not so much the wiring i would need help with, it's building the actual shifter itself i dont think i could manage. but yeah help would be awesome, i love driving cars with tiptronic and i'd love to be able to choose what gear i shift into and when.
                    also with yours, do you have a mode where you can have it operate normally? like just put it in "drive" and have it shift itself like normal?
                    and i also like the torque converter lockup feature you have, i'd deffinately want to do something similar.
                    2004 WJ
