Shifting no no
  • Shifting no no
    When i go to go into first or second i have to like slam it in the tranny isnt letting me go into gear for somereason i think its because im low on tranny fluid or something any ideas???
    95 Yj 4.0, Flowmaster 40 series exhaust, Blue Hids and Yellow Fog Lights, K&N air filter, 2" Boomarang shackles, and sway bar and track bar removal.
    how is the fluid in the slave master?
      sounds like youre synchros are shot....
      99 XJ on tons and 40s....
        mine did that when the slave was going
          I hope its nothing serious and its not at all times that i cant shift only some times its like on and off perfectly to seriously broke i dont get it
            Did you check the fluid in the slave master? I'm pretty sure its near the brake booster master btw
              is it easy to go into 1st and 2nd when your not moving, engine running? if not then sounds like slave cylinder is going. your lucky, the 95's are the only ones with the external cylinder, really easy to swap
                It doesnt want to go in at stops with motor running or moving at some times but other times it goes right in so idk whats up
                  my 94 has an external slave
                    uuuhhhhhgggg.....
                    for the 6th time... check your fluid / slave cylinder
                      ur lucky, i just did a clutch on a XJ with an ax-15 and internal slave, sucked
                        What the fuck language you speakin boy??
                          Uhm i don't know lol i talk terribly some times.....
