Bad Cat?
  • Bad Cat?
    so i started my car today, (2001 jeep cherokee) and it was running really rough, about 100 yrds down the road my check engine light starts blinking. now at first i didnt read the owners manual, and i tried changing my plugs, that didnt help at all. so the owners manual says its my catalytic converter. Now i havent been able to figure out how much one will cost, but all i kno is i have the biggest race of the season thursday and i need to go to NJ. so my question is, 1 has anyone else had this problem? 2 Is it possible for me just to bypass the o2 sensors or even just get rid of my cat and just run it straight back to the muffler? i will eventually fix it the right way, but i need to rig it so that it will work, FAST
    fyi: it runs rough
    it hits like 3000 rpm and just dies
    and it rattles like a mother
    ANY HELP?
    -54 Dodge Power wagon M-37
    -57 GMC Pickup
    -Tim (OIIIIIO)
    drive to autozone
    have them check your codes
    come back
    and post up the codes
    collapsed cat is a possibility in this case, kick the cat with the jeep off and see if it rattles
      drive to autozone
      come back
      x2
      winng. all the goddamned time.
      **MY STATEMENTS AND/OR OPINIONS IN NO WAY REFLECT THOSE OF THE UNITED STATES GOVERNMENT.
        blinking MIL is bad news bears. drive as little as posible. blinking means it could be serious damage on the motor if ran under that condition. get your codes checked immediately
          x2
            so i just installed a new ekwin coil pack, thats what 2 people told me had to be wrong, it didnt fix it, the codes told me that there was a missfire in cylender 1 and that therre was a shortage to an 02 sensor, but could an 02 sensor really mess this thing up that much?
            -57 GMC Pickup
            -Tim (OIIIIIO)
              A misfire on Cylinder 1 can cause your CEL to flash. You can have a bad fuel injector or Internal engine components are bad. Im going through something similar on mine. The O2 sensor could be a wiring problem or a bad O2 sensor.
                bad regulator?
                  check plug wire, rotor for corrosion on the inside and the injector for power.
                    if i remember this right 2001s are a d.i.s system. it had one long coil pack that covered all the plugs?
                      correct, i put a new one in, cost me 250 and it didnt work idk what it is i didnt think of fuel injector tho. im gunna putts with it more tomorrow. till then i have a coil pack for sale.
                      -57 GMC Pickup
                      -Tim (OIIIIIO)
                        50 bucks for your k&n
                        but heres how to bypass 02
                        mayby something to try with jear bear http://zero-signal.org/o2/O2bypass.html.htm
                          bad 02 wont cause it to run THAT bad. it will cause a slight rough idle more then anything. if the 02 sensor gives out your computer just goes off a pre programmed a/f ratio table.
                          a bad cat can cause lack of power etc in the upper rpms. which the jeep off, tap the cat a little, if shits rattling inside it, its no good. Pick up a universal cat for $100-150 or whatever or in the mean time you could just remove the cat, hammer out all the stuff inside it and put a straight pipe or the "shell" of it back in place.
