Ford 8.8 Fab
  • Ford 8.8 Fab
    How hard is it to put a 8.8 in a yj / Are there any that would just bolt right in thanks
    pretty sure none bolt right in but you only have to move the perches a half inch out each... its not too bad. and you need to either get rid of the flange ( highly recommended) or get an adapter. if its a disc 8.8 prlly need a new proportioning valve and other than that it should bolt right in and youll need to make shock mounting brackets
      So this one wont be an easy one eh?
        Its about as easy as your gonna find.. theres no such thing as a really easy axle upgrade very few axles will bolt into a vehicle they werent meant to be in and on top of that very few of those axles are desireable.. id just do it its not that much work
          Its the first fab ive ever done im scared
            It's not terrible, cut off the old spring mounts... measure to correct length weld new ones on make sure the pinion angle is where you want it. then measure for shock mounts and weld those on and your good to go. the yolk is as simple as taking out a nut and putting it back on for the most part and the prop valve isnt difficult and dont forget to bleed the brakes afterwards...
              I also dont know how to weld so its not so easy lol
                urm if ya cant weld id say it aint gonna work.. i mean the leaf pads are close enough that you can prlly get away with it although im not nescessarily recommending it.......
                  Nor do i even have a welder.....
                    Yeah.. id find a buddy with a welder who can do the work for ya... its not terrible you could prlly get someone on here to do it if ya payed for their lunch or somethin lol
                      Also if i get a 8.8 in the rear what should i do with the front
                        Keep your 30 if you dont plan on going above 35s. Just put in one piece shafts with 297 u joints.
                          waggy 44 is the easiest thing to bolting in.. supposedly it goes into a yj wiht very few mods.. youll have a diff bolt pattern front and rear but if you go to adapt-it.com they have adapters from the 5 on 4.5 (8.8) to the waggy 6 on 5.5
                            caleb what the fuck happend to 30's suck??? lol and aren't yj's LP?
                              30s arent terraible for less than 35s. They arent like OMGZZ!!!111!!! the best. and YJs are HP.
