http://4x4xplor.com/t-casedrop.html i was wondering if something as simple as this would really work
Would this really work?
I just wanna do a temporary shitty fix till i can afford the Sye because i wanna go soa this summer anyway95 Yj 4.0, Flowmaster 40 series exhaust, Blue Hids and Yellow Fog Lights, K&N air filter, 2" Boomarang shackles, and sway bar and track bar removal.
drop kits are like bandaids for a missing limb, sure its an effort but at the end of the day...shits still not right!https://sisoffroad.com/forums/core/i...smilies/us.gif 2017 Chevy Silverado 1500 https://sisoffroad.com/forums/core/i...smilies/us.gif
https://sisoffroad.com/forums/core/i...smilies/us.gif 2000 Jeep Cherokee Sport https://sisoffroad.com/forums/core/i...smilies/us.gif
94,95,97 ZJ~SOLD 97,97 TJ~SOLD 00' F350~SOLD
PORC sye is real cheap and from what i hear is pretty much the same thing as the advance adapters one.
idk about yj's but i know on xj's you can run the stock front cv shaft as a rear with the sye. i'd imagine if legnth's were similar and u-joints were the same size it would work tooNo worries, I'm not actually back, I'm just reminiscing about the old days.
i hate when people say that. if its not the most expensive option then its not the right one. its an effective way to eliminate driveline vibrations. the downfall is you loose ground clearance and if u dont do a motor mount lift as well they tend to eat motor mounts. i went through 2 in 3 years without a motor mount lift. u need the ground clearance get the sye. if your looking to fix it to drive it and dont want to dump the coin, do this. same effect on your vibes in the end
Originally posted by greenxj513 View Postidk about yj's but i know on xj's you can run the stock front cv shaft as a rear with the sye. i'd imagine if legnth's were similar and u-joints were the same size it would work too. just need to get the shaft shortened
http://www.performanceoffroadcenter....oducts_id=5068
buy that, and get your self a drive shaft from a junkyard for $40
Originally posted by snowblur17 View Posthttp://www.performanceoffroadcenter....oducts_id=5068
buy that, and get your self a drive shaft from a junkyard for $4095 Yj 4.0, Flowmaster 40 series exhaust, Blue Hids and Yellow Fog Lights, K&N air filter, 2" Boomarang shackles, and sway bar and track bar removal.
yepOriginally posted by Fast Orangeif you piss all over the floor and get 3 drops in the bowl do you count that as good? granted i'm good for a sprinkle or two on the seat, but you leave all of our feet wet, metaphorically speaking of courseOriginally posted by HitItWithSomeSpeedI find adam sandler strangely attractive, it must be josh's fault. god that kid sucks
