anyone ever heard of BB's making everything worse, i put them it and the wobble wot 100x worse, also i can do an alignment perfectly and i get wobble but when i put the front like 1" to 1-1/8" toe in it gets better. this baggles my mind
BB balancing
Originally posted by Fast Orangeif you piss all over the floor and get 3 drops in the bowl do you count that as good? granted i'm good for a sprinkle or two on the seat, but you leave all of our feet wet, metaphorically speaking of courseOriginally posted by HitItWithSomeSpeedI find adam sandler strangely attractive, it must be josh's fault. god that kid sucks
you do know most toe on vhls is toed in a few degrees the reason is when you drive down the road it actually pusheds the tires outward making the angle zero. so if you set it to zero, and then drive down the road it will be toed out. Also you are running 38 inch TLS's they are goin to wobble.
Hey also sorry i didnt call friday I got hung up at work and then had to go try and get my buddys blazer running. i will shoot you a pm in the morning and work out a time i can swing by and pick up those XJ springs85 K10, 44front,ff14 rear, 350,th350,Np208, 39.5/13.5r20 IROKs. almost done
New toy 88 yj, 4.2, 5speed,231. Its getting a soa, 78 f350 dana 60s, SYE, and some 37s.
how many did you put in? you realize with those 39s you will need like 5000 to actually make any somewhat decent balancing? my 35x12.50 radial all terrains took 2500 in each and i wish i put more i still get some vibes. I should have done 3000. with those massive things i would go for AT LEAST 5000 BBs. and if you did put that, than i dunno what to tell ya
Originally posted by Jeepbonehead View Postthats prob the problem i only put like 1000 in each
Originally posted by CumminsJeep View Postthat doesnt look like too many BBs.....how many is that?Originally posted by raze1287 View Postit definitely does not look like enough bb's. have you weighed them?
