shock opinions
  • shock opinions
    well i've got a blown shock in the rear... they are shitty re twintubes for a budget lift so I'm thinking about just replacing all four.
    Is there anything i can get for relatively cheap that is an upgrade or should I just replace the one shock and save my money?
    87 Comanche 4.0 4wd
    cheap does not equal upgrade.
      ok...lets say i have a budget of $300
      any recommendations?
      87 Comanche 4.0 4wd
        RE monotubes can be had for ~that. a little more, but not much
          I say do all 4 at once.....it's just smarter that way. For brands, thats up to you. I have the Skyjacker Nitros, and they aren't too bad, just the firm ride takes a bit to get used to. Plus beware of bad poly bushings
          1998 XJ.....Finally.
          ...And I'm a Mac
            bilstein 5100
              bilstein 5100
              at the least IMHO.
                mine too
                  Rustys shocks are the best ever
                  Buy them now
                    the 5100's are $80 each on summit. about the same price as the re monotubes.
                    87 Comanche 4.0 4wd
                      5100s > RE
                      www.eshocks.com
                        thank you sir
                        87 Comanche 4.0 4wd
                          replace shocks in pairs
                          if the fronts arent broke dont fix em
                            agreed on if front aint broke then dont fix it. 2 rears. seems to me the bilsteins are only 54 bucks right now. spend the extra 30 bucks and get quality.
                              well the shocks are for 2 inches of lift, and i'm at 3 inches right now. I might as well do the fronts too and have shocks that actually work for my setup.
                              87 Comanche 4.0 4wd
