Help me on sway bars
  • Help me on sway bars
    I want to take off my front sway bar but how would i go about doing this
    undo the bolts
      lefty loosey, righty tighty
        sway bars are supposed to be there for a reason just kidding undo the bolts that hold them on
          first you need to tighten the flanagan valve to 64.7 ft/lbs, then the swaybar physically melts out of your jeep onto the ground
            i thought it was 64.7nM... not ft/lbs
              what is this undoing bolts nonsense
              break out the angle grinder
                bolt cutters!!!!!!!!!!!!!!!
                  step 1: go buy beer
                  step 2: go buy burgers
                  step 3: invite over some friends
                  step 4: stare at jeep and talk about it while drinking a beer and cooking burgers
                  step 5: consume burgers and more beer
                  step 6: identify swaybar
                  step 7: take the 6 bolts that hold it and the end links off
                  step 8: drink a beer
                  step 9: go flog it in the woods to admire you handy work and end up getting stuck or breaking something
                  see, its a long complicated process guys
                    The top bolt of the sway bar wont come out on eather side i was wondering if there was a trick i took the pin out and nut off but it wont conme out tried hammer and a crowbar but it wont pop off and there is like a flat head screw on the bolt idk im stumped was about to just angle grind it off but i thought i would ask you guys first thanks
                      bolt cutter the links... works good
                        I would like to keep it in one piece btw
                          Sledge hammer
                            Originally posted by grundlepunch View Post
                            step 1: go buy beer
                            Sounds like youve done this once or twice, eh Dana?
                            and Im still laughing about this reply
                              jerry bransford would be VERY unhappy with this thread
