I don't know much about my Yumbo C110 that I picked up a couple years ago and I know at least one of you, maybe more work on mopeds and the like.
Last fall I came around a corner and when I went to give it gas it died and would not restart, it only cranked. I put it away for the winter and now it's time to get it running.
I had a spare 5 pin CDI and Stator so I installed those. It's got spark. Fuel is coming out of the tank fine, but I don't think it's getting into the carb. I took it all apart, cleaned it and it started right up, but at wide open since I put the throttle cable into the carb wrong. LOL Fixed the cable and now it won't start even on starting fluid unless I let it sit for a while with the fuel shut off. Then it will start for a few minutes and die and not restart again.
I don't see any pin holes in the float, but what are the chances that it's got a hole and is shutting off the fuel?
