Think it's worth it to put 4 to 1 gears in my 300 while I have it out I feel like I don't need them opinions please
Dana 300 4 to 1 gears
Originally posted by konastinky1234 View PostI wouldn't bother man. I don't even feel like I need it with a manual.
Knowing several others who have gone from stock to 4:1, with a 4.0 nonetheless, I bet you'd change your mind if you could experience it.
Matt, with Reds and 4:1 I'd keep the 32 spline output in the back of your mind... Might be fine though. Not much harm in seeing what it will take!97 XJ.
I'm pulling the 231 out of my YJ this weekend to put a SYE on it and thought about a 4:1 kit, but I've got a 4.0 with 4.88 gears so I'm going to just put the SYE in for now and see what I think. I also have a D300 that is flipped and twin sticked sitting in the garage along with another 231 so if I feel I need more I'll build a doubler on the bench and swap that in later.
That's what I've been looking at doing. I want the YJ on the road though so that will be a later modOriginally posted by sardo_67 View PostFor the cost of the 4:1 gears you could put a doubler between the trans and d300. Only cost a little bit more. Then you'll have the best of both worlds.
There are a few kits that use half a stock 231 case and custom adapter plate.
http://www.northwestfab.com/NWF-Eco-...se_p_2403.html
Probably have to flip the 231 if you do a Box-4-rocks97 XJ.
