Cutting Brakes
  • Cutting Brakes
    Im reading up on cutting brakes but I have a few questions still. Can I use cutting brakes set up for the front and the rear with a single handle? So that both brakes on the same axle lock up when I push or pull the lever?
    yes you need double in double out.
    so one master is for the front and one for the rear.
      So that means Ill need a twin handle one, correct.
        If I was gonna bother with a hydro setup, I'd do a left/right cutting brake rear, keep my e-brake, and add a line-lock up front.
        If I were to spend the money on a twin-handle setup, then Id still do that, but then have the front axle plumbed to the second handle left/right.
        but hey, thats just me.
          No you can get a single handle.
          http://www.polyperformance.com/shop/...out-p-283.html
