Here we fucking go again
    one time when i had the covers on my aux lights.... i left them on. battery dead was in an hour and and a half
    yea i think its either a ground or a short somewhere.
      hmmmm..... the battery could be fried too. take the battery out and take it to advance or something and have them load test it
        Even instead of above, don't you just have a different battery, I mean, Christ, you're William D Gentile. The D stands for Diamonds. Anyhoo, odds of there being a drain on the battery that would kill it right after a jump is just plain ridiculous, and even im willing to say that.
        My post was no help whatsoever, but thanks for making me feel special in the tech section. Good luck.
        Oh, and I am going with The Starter AND a dead battery, because its ALWAYS the starter.
        Is it egg nog season yet?
          it is Not the starter. the starter is not effecting this.
          i left the jeep running for a min and came inside, then i went back out 2 mins later and it was idling like shit, almost dieing, rough, so on. i turned it off and had to leave for work
            I mean, obviously i'm not expert but, why can't that be a bad battery?
              where did i say it couldnt?
                just trying to learn..
                  I ate so much ice cream I think I'm going to pass out. But! One day I was driving the sierra, and it started up a little slow. I ignored it and just drove to where I was going. 5 minutes later I tried to start it, absolutely nothing. I thought my alternator was fucked, but I threw in a new battery, and I was good to go.
                    My jeep was experiencing the same symptoms a week or two ago. Ran to autism zone for a new battery and started right up.
                    My bet is the battery is fuct.
                      how are the connections to your starter and solenoid. I've had similar problems when i had a bunch for crap and corrosion down there. Also a week ago my brothers jeep was doing the same thing and everything looked alright. So i went to take the terminals off the battery and his + post pulled out of the battery. Not sure how that happened.
                      If you need me to, not that you cant probably find them on the internet, but i can pull the wiring schematics and all the ground locations off of Alldata at school.
                        thanks guys, i guess ill have to entertain this idea
                        all my terminals on the starter are minty fresh
                        ill let you know, thanks!
                          You flashing codes or anything? "GEN" light? I'de swap the battery with you moms jeep or something first just to see if that works. If its idling like crap and your having battery issues I would assume your not drawing voltage from the batt.
                            They may look minty fresh on the outside but just loosen them and wiggle em a little before you buy a new battery to make sure the inside of the terminal isn't corroded. Happened many times to me on the manche.
                              ill def try swappin the battery when i get a chance at this point....ive heard stories of optima bateries just randomly shitting the bed instantaneously ....ive had this one for prob like 3 years now, we'll see.
                              also corey, i did loosen em up a bit abnd give em the treatment, ive had too many starter issue in the past
                              either way the starters turnin, this seems to be battery related
                                Hey Will, why dont you try switching the battery? I dont think it's been said yet
