Painting/Fixing up WJ sliders
  • Painting/Fixing up WJ sliders
    I am getting really sick of seeing the terrible rust holes that have developed on my Overland sliders. I don't have the money right now to buy new sliders, and I haven't found a set I really like...so I want to fix up the current ones.
    Here is what I am thinking...please let me know if you have any other ideas!
    Remove the sliders and end caps - get rid of all rust
    Sand them down and clean them
    For the spots that have holes - use an expanding foam type of deal and fill the holes
    Use something like this https://www.rustoleum.com/CBGProduct.asp?pid=40 to cover the rusted spots
    Finish with another layer of paint
    for aesthetics and not to slide over rocks:
    break away rust
    sand to clean up
    expanding foam underneath, sand/carve excess
    bondo over top of that
    paint paint paint
    or skip all that and hire someone to cleanly metal patch it to avoid any potential problems with the foam over long periods of time
    but what do i know
      nothing
        Expanding foam will just cause it to rust faster.
          expanding foam is likely to capture some trace moisture, sure
          considering they are rusting from the inside out, the only way to truly fix them is to cut the entire section out to remove all rust inside, and replace it with new metal. the realistic scenario is they are formed metal pieces and patching isnt straight forward or easy, not to mention we dont have a welder, so expanding foam/bondo is a good fix for the mean time. some day the jeep will need new sliders, at least with this it wont look like its full of rust holes. the holes are small, the rust cancer inside isnt.
          removing all the rust we can, coating it, and then foaming, bondo'ing, and painting, is the best budget fix i can think of short of metal work
          after all its a slider not a quarter panel and the holes are very small, and its a winter fix before theyre replaced with something else
            Thin sheetmetal, cut out the cancer, weld new sheetmetal in, grind/sand smooth, paint.
            I know a guy that knows a guy that may or may not do some welding. He goes by "The Pastafarian".
              read before post
              or consider the reading before repeating
                Take them off before they get too bad. Sell on JF for lots of money..buy JCR
                  really not a bad idea..
                    JCR are too expensive for me right now...at least the ones I like. Like Will said its just a temp fix for now to get through the winter.
                      Pictures go a million miles when talking about rust.
                      If this is a "temp fix for now" why even bother? Instead of buying the foam, paint, etc etc, just toss that in a mason jar labeled "Slider money". You'll be about ~$40 or so closer.
                      Hudson
                        Sell them now while they are still in decent shape. Go winter without them. Buy in spring or when JCR has a sale. Not to say you'll get this because they have some rust, but I've seen those go for $400 on JF. Even if you only get $150-$200 that's a good chunk for new ones......
                          she wanted them fixed to look nice in the meantime, I am not trying to talk her out of it, its her jeep
                            To be honest with you I probably won't end up buying sliders unless I got a good deal on overland ones in better shape. I like how they look and my jeep is never going to be wheeled hardcore. So I'm going to start with this temp fix and see how it works out. I have a bunch of other rust spots on the jeep I need to worry about as well, this is just one of many places that needs repair.
                              Fair enough, it sounded like you were gonna buy new ones anyway. I too love the look of the stock overland ones. They are also 1/8" so they aren't useless by any means. Just in case Gill wants to get frisky on the Rape Whistle
