Fuel Cells
  • Fuel Cells
    Where do i get a decent fuel cell for a decent price? what else will i need?
    Summit Racing.
    All kinds of different sizes. Most series require a steel shell with a plastic bladder. They run about $170-$300ish. They're red.
    If it's going into a Jeep, someone makes a JeepSpeed one that the OEM sending unit will bolt right up to, I believe.
    If you get one of the universal ones you have to figure out fuel delivery on your own, standard is some walbro pickups at the bottom of the cell and an external pump. You can run an internal pump, but I haven't really looked into it.
    It's easy to get carried away and spend a lot on a FuelSafe, Jaz, RCI, ATL
    http://www.summitracing.com/search/p...d-powdercoated
      Rci makes one I think 20 gal that your sending unit will fit into. Check out gen rites page.
        I don't like the little quarter turn plastic cap.
        I went with the screw style cap on my new cell.
        Artec makes mounts for JAZ cells but only a few sizes.
        I got my JAZ cell from Polyperformance.com
        If you spend a little more and get the one with the large oval cap makes it easier to install fittings and pickup etc.
        You will want either a surge tank or walbro pickups that part gets pricey.
        But it really sucks when you need at least 3/4 of gas to drive up a climb.
        Don't use foam it breaks down and clogs your pump, search Pirate you can buy other stuff.
        Internal pumps are better it keeps the pump cool, but a the same time harder to change the external pumps don't last as long nosier but easier to change.
        You can sometimes find used ones like on Pirate.
          i have a JAZ fuel cell in my garage, been there for about 6 years now. don't remember why but it was supposed to fit between the frame rails on a Ford Ranger. probably 25gal i think. want me to pull it out and measure it for ya?
            I looked at it quick. About 14in deep and 27x28 on the top.
              Are you saying you want to sell it?
                Oh my bad, yes.
                  So bump, I bought a fuel cell, it has foam in it, can I take it out? What do I do about AN fittings? How do I order fittings and lines and shit? wha about fuel pick ups?
                    The fuel cell has a line going in underneath the foam.
                      How old is the fuel cell.how long do you plan on keeping the cell.the only time I've had the foam break down on me is in fuels cell 10+ years and older.so if its a fairly new cell you should be ok for.a while.
                        I honestly dont know how old it is.
                          Why take the foam out? It's in there for a reason.
                            This. I have had good luck with foam <7-8 years old. I like to change it every 4-5 to be safe though. It sucks when it falls apart.
                              There are some pretty I'm depth fuel cell tech threads on pirate. Also check out alltech motorsports thread on submerged pumps.
                              I know tim sells the walbro pickups you're going to want.
                              Is this for your jeep? Ranger? Fuel cells being used for offroad stuff are set up a little differently depending on what you're doing and fuel needs.
