93 T-Case In A 99 Sensor Question?
  • 93 T-Case In A 99 Sensor Question?
    Bought Dans SYED NP242 out of his 93 XJ.
    Long story short, i dropped my case, and bolted his in. I still have the trans/tcase supported by a floor jack so i still have full access to everything.
    I just need to know how to deal with the sensors. The 93 has two sensors both located towards the rear shaft area. My (99) has two sensors as well except one is located directly above the paddle shifter and then one on the rear shaft area. The actual connects are different so i can't just reach the plug over and plug it in.
    I recall reading how to fix this problem somewhere but i can't find it now. Does anyone know?
    On another note, does anyone have any shims (i need about 4 or so degrees) and located around the New Milford area?
    Hudson
