So according to the Haynes manual compression in a 6cyl should be between 120-150. I have a cylinder 1 misfire and since swapped the injector, replaced the plugs, cap, wires, and rotor.
So I did a compression test and cylinder 1 is down to 117psi. The other 5 Are between 128-142.
It's out of range but only by 3psi. That enough to kill combustion in one cylinder?? I threw a can of restore in the oil hoping that would do something.
This isn't my daily driver but what would you guys do here?
