d70?
    yea i think it probably would.....its worth a shot
      there is no need for this axle unless your running 44" tires
        i've seen them go usually for like 2-3 hundred
          ive never seen em for sale for all that much... supposedly the full float shafts bolt into the 78-79 250 dana 60s tho if you bore the spindles and get a new carrier etc etc.
            yes that true, you should be able to use the d70 spindles on a d60 and the shafts/carrier
              you will need to find a moron to pay more than 300 for that axle.
              1 ton rears are a dime a dozen
                alright cool thanks.
                  the difference is 70's are dime a dozen, unlike the D60. The D70 can be had for 100$ all day long as well. But for the record, they are stronger then a 14bolt.
                  If you want to sell it, let me know. i have a yota chassis sitting here that needs tons and i think the 70 would be cool.
                  Originally posted by gmc4cw
                  if someone can look at your rig and still tell what it was, then you have a long way to go before its destroyed. if you continue to wheel it after said destruction then you are truely special. :shock:
