http://claytonoffroad.com/product_in...roducts_id/311 In the discription it says it requires 6.5" lift to clear floor. sooooooo this wont work with 4.5? i dont really feel like cutting my floor
Attention zullo and others!
I could never figure out the radius arm unloading thing. Of all the time I wheeled my jeep with them, I never had a problem.
If you really dont want them, but they kit and clearance the floor. It cant be too bad. If they are designed to fit a 35" tire, and will clear until the tire touches the fender, than it doesnt matter if its 4.5 or 6.5". Same uptravel.Dan.
Originally posted by ct67_72 View PostIf they are designed to fit a 35" tire, and will clear until the tire touches the fender, than it doesnt matter if its 4.5 or 6.5". Same uptravel.
and with the 35s i could have maybe 3 inches of uptravel. idk. ill have to figure it out. i wouldnt mind having the radius setup. its still a long arm. from what i understand the 3 link doesnt have the binding radius has so therefore flexes more freely? correct?98 xj, 4.0, AW4, 231 AA SYE, 4.5"RE/RC, CA drop brackets, 33s, and some other stuff
Correct. No binding with a 3 link. There are some other advantages as wellDan.
I'm sure there is some very good, well thought out reasoning behind that too...Dan.
Originally posted by Dirtyjeep92 View PostNow i have no clue what to do about a long arm setup. I dont really want the radius arms because off unloading but i figure i can just run straps.-98 XJ 4.5" lift , 35's, trimmed, locked, geared, flexy
-54 Dodge Power wagon M-37
-57 GMC Pickup
-Tim (OIIIIIO)
I ran my radius arm setup for awhile and liked it.
I built a 3 link when i went to 1 tons similar to that clayton setup except I had the upper link on the passenger side (I would think that you would have serious clearance issues in a lower lift cherokee with the driveshaft and the upper link) and it drove the same as it did with the radius arm setup. I have no beef at all with a radius arm.
