oil pressure gauge - cold weather
  • oil pressure gauge - cold weather
    will thinks its the oil pressure sending unit, but just want to know if anyone else has had this issue/fixed it
    has only happened 2 times, both in the past month. both on very cold mornings. i'll start the WJ up, and the oil pressure gauge doesn't move. stays on L. turn the car off, start it back up, reads normal pressure, no issues whatsoever.
    Does it eventually come up after its been running or do you HAVE to restart it for it to work?
      i havent tried...the first time it happened i had started my car before i left for work, it was probably running 10 mins or so. when i got out to leave for work is when i noticed it was on L. so im guessing it was never going to go up. the 2nd time when it happened this week i just turned it off immediately so i didnt give it a chance to try. but as soon as i started it again it went right up to normal pressure without hesitation
        hmmmm it would be weird for the sending unit to stick and have restarting affect it. They usually either work or dont. Do you know anyone with a real automotive scan tool? If you can find someone with one that will read data you can see if the pcm is registering oil pressure and rule out the sender.
        I dont think it is. It could be but it would be an odd failure for one.
        I guess you could do the same with a meter also and see if the sender is working. If you can get someone with a good multimeter to check it I can look up the spec for it.
        I just looked up the oil pressure sensor on napa and its like 9$ so really, it wouldnt hurt to try it anyway.
          I have a tool that'll read the live data.
            now...we just have to make it do this again
              When its working does the gauge move as rpms and oil pressure increase?
                it usually goes straight to normal and then doesnt move while im driving
                  These later ones may be a "switch" and not a sensor anyway.
                    Exactly, it just goes to a predetermined spot on the gauge as long as there is oil pressure. Get a good scanner and see if it will read actual oil pressure.
