Yes i did the combustion leak test with the engine running for about 15 minutes. Was at operating temperature. Sucked about 4" of coolant out of the radiator fill cap, and put the tester in, and let it suck air. I even saw the steam or whatever was rising into the test tube. Didn't change colors or anything.
Is it possible that i have a bad intake valve on cylinder #1? If so, how do i check for this? I can't for the life of me get air to stop coming out of the intake. I have been constantly feeding air into the cylinder, and watching the gauge. I can see the gauge begin to rise in pressure, but at no time does air stop coming out of the intake.
I'm going to see if i have any better luck in the second cylinder.
Is the intake rocker the closer one to me, or the farther one away? I'm assuming when it rocks up the valve is closed, and when it's down all the way, it's open, correct?
Here's a picture of where i think the crack in the head is. Does this look like a crack to you?
I began removing parts from the jeep to make the head easier to pull. Am currently soaking the exhaust manifold in kroil so it gets nice and loose for me.
I just saw the crank mark. Should i line it up that little notch in the pulley at 4 (like in the picture) or at 0?
I feel dumb.
I feel dumb.
