i finished up the instal of my 4.5 RC lift on the xj today. i installed the transfer case drop on driver side no problem. passenger side one bolt broke and other wont come out! need help suggestions?! i get some pretty good vibes goin down the road any help is appreciated!
T case drop help! broken bolts!
If the head is snapped off, you could drill into it with a smaller drill bit than the diameter of the bolt and use an EZ out to back it out. If that doesnt work, you could drill the hole out using the same size as the diameter of the bolt and retap it to accept threads again.
Prairie..... Can you honestly tell me that you have EVER gotten an easy out to work on a bolt that broke because it was rusted??No worries, I'm not actually back, I'm just reminiscing about the old days.
or does anybody know of a long enough front Double carbon shaft i can put in the rear? i used a for exploder front shaft in the front of my zj for a little while maybe somthing similar out there a little longer?98 xj, 4.0, AW4, 231 AA SYE, 4.5"RE/RC, CA drop brackets, 33s, and some other stuff
Yeah I have, with lots of heat also.Originally posted by JeepBabiiXJ View PostPrairie..... Can you honestly tell me that you have EVER gotten an easy out to work on a bolt that broke because it was rusted??
As far as using a dshaft in the rear, if you have a 4.0/aw4/231, you can use an XJ Front shaft from the same combo in the rear.
Heat being the key factor!!Originally posted by Mike View PostYeah I have, with lots of heat also.
As far as using a dshaft in the rear, if you have a 4.0/aw4/231, you can use an XJ Front shaft from the same combo in the rear.sigpic
Heat wrench until the bolt turns cherry red. Then try vice grips. Just dont concentrate the heat on the bolt, concentrate it on the hole to make it larger. I had the same problem with mine so I heated the outside, then used a product called Freeze Off to cool the bolt and then vice gripped it out.I don't always drink orange juice, but when I do, I prefer to chew it. #madpulp
