Motor Mount lift
  • Motor Mount lift
    Are mml supposed to be such a ****en pain in the ass? Any advice how to move the motor around to line up the motor mounts?
    05 Black Rubicon
    If you do 1 side at a time it shouldn't be too bad also put a jack under the oil pan with a small amount of pressure so the bolts will come out easy/er.
      I lifted off of my transmission bellhouse and just man handled the engine around until the bolts lined up
      Where are you located? If you need some help I'm willing to give a hand
      2002 TJ Sport 3" AEV coils with OME LTs
        I messed with it for a few hours and got the motor mounts in place. thanks for the tips. What i noticed worked better was putting the through bolt first then lifting each side to get the mount into place. Def recommend anyone doin this in the future to do one at a time, I had already removed both.
        05 Black Rubicon
