so the other night my water pump and thermostat both decided to go bad at the same time. i didn't know my 98 tj was over heating and it shut down on me on the highway, got a tow home and put in a new water pump and thermostat. now the engine is running crappy, not much power and i'm getting a missfire reading on cylinder one. i changed the spark plug and wire...no difference.......any advice??? shot head gasket, ring??
engine help
yep, probably head gasket.Dan.
the best way is to do a leakdown test. This should point to the right area. You can also check for bubbling in the coolant like Tom said, sometimes its hard to tell that though. There are also analyzers to check for exhaust gas in the cooling system.
I happen to have both.......Dan.
also if you have a compressor and a compression tester, you can make a makeshift leakdown tester. Especially when the compression is that low.
remove the gague from the hose of the compression tester and install an air line fitting. scres it into the cyliner and fill it with air. The cylinder will have to be TDC compression stroke, and listen for air escaping and watch the radiator for air bubbles. I have a feeling with compression that low it will be pretty obvious, oh and pull the oil cap and listen for air, if its pressurizing the crank case.Dan.
Originally posted by ct67_72 View Postalso if you have a compressor and a compression tester, you can make a makeshift leakdown tester. Especially when the compression is that low.
well, got my hands on a good head, put it on but the rod for cyl 4 wasn't put in the right spot but didn't know it, turned on the engine and it bent. took off the head, put in a new rod in cyl 4 and got running again but now it's not running that great. did a compression test and cyl 1-3 @150 and cyl 4 @ 130......any ideas??
Originally posted by kev711 View Postyup, got the correct pushrod in. one guy said i might have bent a valve so i'll have to replace a valve but that's way out of my leagueDizz dizz go sleep sleep
Driver 4677 FSM vehicle
so i decided to give it a shot and just drive it on the highway for about 40 miles. when i got to my destination, i noticed the engine sat at idle really nice and had plenty of power..well as much as you're going to get from a 4 banger. today i did another compression test and tada!!!! all 4 squirrels we kickin at 150psi! i guess i had a stuck valve in 4.....so happy
