ANY LINKS AND INFO WILL BE OF GREAT HELP THANK YOU.
Heres the deal, theres a great deal of stupid turbo Honda's being built here, and mustangs and camaros oh and theres that one guy we all know thats oh so concerned with the god damned Rotary...... but.....Im a Jeep guy and decided im gonna build a remote mounted turbo XJ based off of 505 performances kit. Couple of questions regarding timing and fuel.... is there a way around buying an expensive ass piggy back system to acheive timing retardation.
Borg/Warner turbo internally gated.
Looking to run between 6-8 lbs of boost... What I wanna do is run a 2 bar map sensor. Any reason why this wont work....?
V8 Explorer injectors.
Im not looking to run a top mount w/a cooler. Its either gonna be non-inter-cooled ( which i have seen done prior) or FMIC ( never seen done yet) Figure with the stock air box, a/c compressor, condenser, battery running dual electric fans should leave a substantial amount of room to work with.
Stock internals. Im gonna pull the head and do the head gasket and manifold gaskets immdediately all the while inspecting for any potential problems from the get go.
A/C and Condensor are goin bye bye
Batterys being moved to the trunk.
Need as much feed back and knowledge as possible so anything and everything will be of help. Thanks.
