wiring LED lights for 1/4 panel armor?
  • wiring LED lights for 1/4 panel armor?
    ordered THOR 1/4 panel armor the other day and im curious on how to go about wiring this up for LED lights. they look like this:
    id like to add another light to the side to keep it more legal (1"x4" red turn signal im thinking)
    i found this thread: http://www.naxja.org/forum/showthread.php?t=980571
    that shows a pretty simple way of doing it, but im not sure how i would add the side blinker to that.. i want it to do the same tail light/brake light/blinker as the oval shaped one, is it as simple as splicing it in with the oval shaped light or more involved?
    I thinks it's pretty str8 forward but you will need a different relay? I'm sure someone here like andrew or will can tell you better than my myself.
      I did this. You need a flasher relay that will work with LED load and probably put a diode on the ground side so there is no back feeding. Use the search I may have explained it on my post.
        http://sisoffroad.com/forums/showthr...&highlight=LED
