putting an xj front driveshaft into the rear of my cj. cj's come with fixed yokes on the t-case but no double cardan driveshafts. plan is to take the front tc yoke with the driveshaft from the jy as well. both yokes are 26 spline and i've read they've been swapped successfully. it has to be on here somewhere but i can't find it. the xj front shaft uses 1310 ujoints on the axle side correct? thats what the amc20 uses. anybody forsee problems swapping the yokes?
xj front driveshaft ???'s
Isn't the double cardan end on the welded on side?
What length do you need I might have one.
Also a NP231 front yoke will bolt onto the D300, so you can have your double cardan.RCrocs #123 Brown CJ-5
