skid plates w/ clayton long arms
  • skid plates w/ clayton long arms
    what skid plates will work with my set up or do i have to make my own looking for a t case oil pan skid
    97' zj
    2012 surbra imperza DD
    Recent naxja discussion says nothing will bolt up.
    http://naxja.org/forum/showthread.php?t=1027295
      weld a piece of plate there. for what its worth, i never ran a tcase skid and never had any problems.
      edit:
      OOOOOOO I liky very much what this guy did....
        i looked at that pic before its a really good idea but i couldnt make that lol
        97' zj
          Its really not all that impressive. It's very Simple and effective. He just got a piece of plate and cut 3/4 the way through the plate 3 inches in around the outside and bent it up.(After further review I don't know if he cut through the plate before bending it. But, that is a method you could use for doing it yourself.) Then welded the seems. And drilled some holes in it.
            most of that looks like it was done with an Ironworker
              Originally posted by cherokee-at-16 View Post
              Its really not all that impressive, very Simple and effective. He just got a piece of plate and cut 3/4 the way through the plate 3 inches in around the outside and bent it up.(After further review I don't know if he cut through the plate before bending it. But, that is a method you could use for doing it yourself.) Then welded the seems. And drilled some holes in it.
              I take it you make better ones...
                not for nothing but hes right its not rocket science.. grab and angle grinder and a welder and you can make that
                95XJ tons 3 link 36s 5:38s
                97 F-250HD 7.3 Turbo Diesel
                "Shut up and Wheel"
                  Sorry, should I have said it really not that difficult to make instead of impressive. It was just the first thing that came to my mind when typing. I wasn't trying to sound cocky.
                    May be true, but it's still simple, effective, and appears to be pretty damn strong.
                      you never realize how easy it is to build shit, till you try it.
                      Dizz dizz go sleep sleep
                      Driver 4677 FSM vehicle
                        like i said.... it's not rocket science
