I'm trying to get my new RE 4.5 leafs in right now and i have a dilemma. One of the bushings (the other is fine) is too small for the stock size bolts to go through. The side closest to the front obviously has to utilize the stock size because the bolt is welded inside the uniframe and you can't just use a different size bolt.
Ok, so i tried using a different size bolt for the shackle mount side which then puts the center pins too far back and nothing lines up right.
Is it possible that they pressed a smaller bushing in by mistake? Should i just punch the bushings out of my rustys packs and re-use them?
