Here is my idea...
I want heim steering to replace mah shitty stock job. Yes it is a driver and Yes i know that it advised against but i want beef without reaming knuckles and such... I can weld so i wanna do it by mah self.
However I want to keep the stock configuration of the tracbar seeing as I just bought a RK trac-bar.
This is my idea. Basically the exact same thing as a JCR WONTON or Banditt WONTON but with heims and UTK.
My very crude drawing of the draglink. The top drawing is the front veiw and the bottom is if you were looking form the top.
Basicaly i will have a double shear mount for where the tie rod and the draglink come together with a notched small peices of tubing welded on the draglink where the bolt will go through.
This gave me the idea.
http://pirate4x4.com/forum/showpost....6&postcount=26
I know it will work as far as packaging... but i know people complain of tie-rod roll with inverted-t and i think UTK but if i am thinking of this correctly the heims will eliminate that roll.
So my question is.... Do YOU think it will work as far as no bump steer and hold together???
has he said anything about how that setup worked?
