Gas Tank Tuck.
  • Gas Tank Tuck.
    whos done one that would like to help a brother out.
    or... atleast offer up some info/pics of yours for referance.
    appreciated, thnks.
    #becauseJoeNitro
    Cut the floor above the tank raise it up, and support it.
    Good luck
      how i did it:
      cut shit up
      drop in stock gas tank skid in the hole
      fold the crimped ends of the stock tank in
      weld supports fromside of jeep to side of jeep
      skin with sheet metal
      i made mine removable for ease of maintenance
      might want to use fairly heavy guage metal. i used 22 guage i think and shit bends and folds
      build up a fuel filler rail
      chop off fuel filler at the body.
      relocate 6"ish higher
      weld in place
      weld metal covering up old hole
        Good luck
        that is nice and clean, prob the nicest looking one i've seen done
          Thank you,
          I had an extra carpet that cleaned it up nice.
            i gotta skin mine with some carpet.
            shits loud
              Good luck
              Oh shit. I thought you just posted a picture of the trunk
                ^^^^ that is clean as hell man,
                  any pics from below?
                  -Tim
                    I know it is hard to tell but that is it sitting on the ground the jeep is completely stock usually the gas tank is below the leaf springs.
                    If you go any higher you need to raise the fill right now it only about an 1" lower than the fill.
                    This is how I supported it you can see on the front cross member I raised the shock mounts up as well. I put a couple more braces to support the sheet metal floor.
                      very nice, this definitely looks like a project which may begin in the future
                      -Tim
                        only pic i got mid-build
