crossmembers?
  • crossmembers?
    just a quick inquiry. is there any difference in crossmember specifications between the aw4 and ax15 equipped XJs?
    1945 Willys-Overland CJ2A
    I believe that the ax15 hangs lower.
      hangs lower as in and ax15 will sit high on an aw4 xmember? anyone know if there will be any clearance issues?
        As in the cross member connects to the frame rails and swoops down like a half inch or something lower then the auto cross member would. If this is correct, which I think it is, then yes the ax15 would sit higher on an aw4 cross-member.
        Clayton x member example:
          roger, thanks
            And I would bet money if Clayton makes you select between cross members then there must be clearance issues.
