i need bearings
  • i need bearings
    i need to get new bearings, seals and all that good stuff for my xj 44 shafts. what and where do i buy these for a decent price
    i have the XJ dana 44 outer bearings these
    http://www.quadratec.com/products/52449%201096.htm
    25 bucks
      excellent i'll take them pete. can you ship them? also what else do i need for the shafts. i'm an axle shaft noob
        timken set-10 from autozone
        24 change
        or napa brg-10 for 41 change. (also timkens but repackaged)
        yea, i have the part numbers memorized
          that sounds like french to me man i'm confused. should i deal with autozone for u-bolts too or are they going to screw that up
            let me know if you want the ones i have or see if you can find em at autozone
              i run grade 5, 9/16" fine thread u bolts from advance.
              i buy the 2" "leaf spring lift kit" they have which is just blocks, but you get the blocks and 4 u bolts for cheaper than buying 4 u bolts separately. i just throw the blocks out so nobody dies
                I am running the ubolts from a kit just like that. Happened to have them sitting around from the burb.
