ok so i got my tj up i think about 4 inches over stock on suspension but am not sure the exact height, i used zj springs with a coil spacer from a wj rammed into the top of them so the spacer i s 2 inches and the coil gives about 2 inches anyways. now my axle is somewhat off center a bit and i need to know how to set up my trackbar for this. i bought an adjustable for a 4 inch lift but what do i do? just throw it in and adjust till the axle is centered? should i get a drop bracket? or is there more to it? also isnt alignment supposed to be off? because i drove around with it like this and it was just the same as before.....
now for the rear, it is almost as high as the front with stock coils on my custom 8.8 brackets which are tall. i am trying to find some slightly higher solution for this and that axle is slightly off center so i may need a trackbar for that too i guess but it's been fine all this time so idk.....
please advise/help me
thanks
thanks
