60 camber problem
  • 60 camber problem
    Looking at the front of my jeep the front wheels have a lot of + camber. If this from lack of weight or what?
    pics? my friends 80's d60 sits like that
    silly thought, but are the hubs and wheel bearings tight?
      I don't think the weight of the vehicle effects the camber on a solid axle.
        Not the best picture. I read that there are shim that go between the hub and spindle.
          2 of my friends that have 60's swapped in sit the same way
          when you re-built the axle were there shims in it? or is it an aftermarket part?
            There were no shim. I rebuilt the kingpins, new bushing, new lower bearings and races and the highsteer arms are WFO springless arms.
              I've seen a few that sit like that as well
                Ok, I'm not gonna worry about it then unless the tires start to wear really bad. I'll be sure to rotate them a lot.
                  I love that jeep
                    sexaayyy yj
                      Mine sits like that. wait till you catch it when you park at close to full lock. I always have to double check that my fucking wheel isnt falling off when I do, no joke.
                        I was going to say it was the kingpins but you did that already. Hows the pinion angle?
                          Pinion angle is stock, along with caster, the perches are close enough to use the factory perches on the yj.
                            They do make shims that sit behind the spindle to correct this. I'll see if I can find the link. I have them on my HP44....
                            - 99TJ 4.0 4.5 RE springs, Clayton 5in LA stretch, GenRight Armor, 35x12.50 bfg mt, currie hp9 rear w/ 35 spline detroit, hp44 w/ arb and 4340 axles, k/n fipk, banks headers, warn xd9000i
                              Thanks man, I have part numbers I found but nobody seems to have them.
