guide to trimming fenders
  • guide to trimming fenders
    Hi all, So finally decided to trim my fenders. But needs more info. So do any of you have a link of the guide to help me. thanks
    By the way, i have searched a little, and have seen them in the past, but I figured it would be easier to just ask. Thanks again
    4x4 Station Wagon...
    http://www.cardomain.com/ride/3016241/9 hope this helps
      Get help from other members?
      It's been working for me thus far.
      Is it egg nog season yet?
        allright thanks guys
          be careful on the rears i accidentally cut a little too far now i got some sheet metal work to do.
            x2
              So from what i' ve read. On the rear I do not want to cut past the pinch seem. Which I believe caused the problem that you guys had with the split sheet metal.
              But, my question is, What is the best way to cut the front? Should I use the cut and fold method, or should I use a angle grinder?
                angle grinder or sawzall will work fine.
                Originally posted by fullwidthxj191 View Post
                x2
                you cut too far too or just warning him?
                  i have angle grinders, sawzalls, and tin snips. we'll do it on sunday when were doing viteks lift
                    dont even bother with the samzall, just makes a mess, the angle grinder will be your friend. and on the rears make sure you make plenty of cuts, if you make too little the curves will come out choppy, good luck
                      angle grinder.
