front passenger water leak
  • front passenger water leak
    Hi, I have a water leak on the front passenger side that pours out the bottom of the dash board. Someone mentioned something about the heater box at one time to me. Does this sound familiar to anyone? Any hints would be helpful. Thanks, Michelle
    I have the same problem...it goes under the carpet I believe and makes it all wet and I have no idea of what it can be..I also have it on my driver's side too, but even worse
    97 Chevy Blazer LT 2" Body lift, 2" Suspension lift, 31" General Grabbers AT2. Sold
    96 Jeep XJ Classic 6.5" RC lift with 33" Duratracs. Sold
    00 Jeep XJ Sport 4.5" lift 33" BFG MudTerrains
      What kind of vehicle is it?
        http://sisoffroad.com/forums/forumdisplay.php?f=3
        95 xj JY 3" 35" truxus mt's
          Originally posted by murdered out manche View Post
          getting good at that
          1992 xj Briarwood
          Welded front and rear
          13' LED roof lights
          Disco ball
          Truck nuts
          Spinners
            thanks for noticing cupcake, i try
              if its an xj check the line for the rear window washer
                also heck the unibody seams in the front under the hood in the corner near the heater box, over time the seamsealer tends to crack.
                  To know for sure if it's the heater core leaking like that, turn on your defrosters on and let them run for 15-20 minutes. With a leak large enough to make a puddle on the floor, then you will undoubtedly get a film that develops on the window from the fluid from the heater core.
                  Easiest test for the problem, i'd start there.
