Is this a D35?
  • Is this a D35?
    Im pretty sure I have a D35 but not sure.. what is it
    1994 ZJ- sold
    1998 XJ-sold
    2011 F-150 ecoboost- daily
    1994 ZJ- 5.5 lift blah blah blah
    - Mike
    Yes it is. Upgrade time.
    -1988 Comanche 31's, rot box
    -1990 Comanche 35's, 44 locked, beater
    -1977 F-250 Highboy 35's, gas pig
    -2012 6.7 Powerstroke 37's, tow rig
    The junkpile keeps growing!
      damnnit
      1994 ZJ- sold
      1998 XJ-sold
      - Mike
        Ford 8.8, easiest to find and install
          this. or if you cant find one, a 29-spline 8.25 from 97+ XJ
            29 spline 8.25 would be the cheapest /easiest way to get a reliable axle that will withstand 33's
              Yes, been running mine for years.
                pretty sure that is an 8.25 with the push in plug like that I think dana's use threaded plugs.
                You can try some google searching.
                  definitely a dana 35..look at the shaping of the diff cover face versus the 8.25
                  plus it doesnt have a flat lip below the cover on the actual housing center section like an 8.25 does
                  plus it doesnt have a big lip/ridge around the side of the mounting ring
                  wanna be quadruple sure? check that tag on the top bolt, or measure your axle tubes. d35 is gonna have 2.75" tubes verus the 8.25's 3"
                    Will's right. The 8.25 doesn't have as large of an "indent", if you will, in which the drain/fill plug is set and has a flat bottom.
                      i had a d35 with a push in plastic plug.
                      Its a d35
                      pull it from your jeep and scrap it... or sell the shafts to someone that blew up their 35
                        Or make a sculpture out of them.
                          Never noticed the push in plugs on a D35, I don't see to many D35s to begin with.
                          I agree D35 I see it now, now easier to tell in person
                            I had a push-in rubber plug in mine, got rid of that turd!
                              Thanks guys, I think I am going with the Cryco 8.25
                              1994 ZJ- sold
                              1998 XJ-sold
                              - Mike
