Single plug connectors
  • Single plug connectors
    Looking for a good solution for my new LED bars
    I am looking for single plug connectors (weatherproof) that I can plug and unplug with ease. Looking to avoid having permanent butt connectors or similar.
    Local acquisition ideal, as I need them before I leave Friday for california
    Like any light, its a hot and ground coming off it. want it combined into 1 plug harness.
    get some weather pack connectors...
      x2
      1945 Willys-Overland CJ2A
        didnt know what those things were called, lookin into em now thanks
          whats in california?
            liberals and shitty gun laws
              If you can't find them anywhere else check boaters world or Boat U.S. I would use that as a last ditch effort though. Just because it says "boat" on it they will jack up the price
                What guage is the wire?
                2013 F150 fx4 (Tow Pig/DD)
                • 5.0 with the 3.73 option
                2003 TJ Rubicon
                • 4.0/42rle/np241or
                • 5.13's
                • 33” BFG KO2s
                  I got you covered. just let me know what size the wire is... I'll pick it up at work.
                  2003 TJ Rubicon
                  • 4.0/42rle/np241or
                  • 5.13's
                  • 33” BFG KO2s
                    i have one you can have... but just one
                      off the top of my head, it is probably 14-16...lets go with 14 to be safe. thanks josh!!!!!!!!!!!! need em for the two separate amber LEDs and big LED...so male/female for each
                      Dillion, you are a hoot.
                        http://www.napaonline.com/Search/Det...176_0063685165
                        would this work??? and you would need 3 of errything??
                        2003 TJ Rubicon
                        • 4.0/42rle/np241or
                        • 5.13's
                        • 33” BFG KO2s
                          i was looking at those last night, but the pigtail versions (wires in the back of em comin out)
                          i need 3 male 3 female connectors.
                          how do you crimp the wires to the inside of those?
                            They ends that plug into them are seperate from the clamshell... you crimp and them insert into "tube"
                            Or... hows bout a 2 wire trailer connector??? just throwin out ideas...
                            http://www.napaonline.com/Search/Det...598_0006462383
                            2003 TJ Rubicon
                            • 4.0/42rle/np241or
                            • 5.13's
                            • 33” BFG KO2s
                              You pull the contact pins and crimp the wire right to the pin, or throw a little solder on it
