Front and rear diff question
  • Front and rear diff question
    Hey does anyone have any suggestions about front and rear diffs for my zj,i will be runnin 35's on it.I was possibly gona run the d30 up front and was wondering what rear would be the same width as stock that will hold up to the 35's.I dont want to run the d44a.I dont have a problem making the brackets to make something else fit in it,but i dont think i wana go as far as a dana 60.Thanks for any help.
    have you looked into a 8.8?
      Same width as stock.
      Find an 8.25 and weld up all the spring plates and control arm brackets to it.
          Another vote for the 8.8. But also look into a reg 44 or 9 inch.
            The 8.8 are out of an explorer/mountaneer right?what years did they use disk brakes?
              95+ i believe
              Dizz dizz go sleep sleep
              Driver 4677 FSM vehicle
                96 or newer 8.8 and run a hp 30 upfront and you'll be good for 35's
                  8.8 and HP 30 will do the job make sure you run the ABS shafts at least up front
                  95XJ tons 3 link 36s 5:38s
                  97 F-250HD 7.3 Turbo Diesel
                  "Shut up and Wheel"
                    297x
