Slow Windows
  • Slow Windows
    My windows have always been quite slow when either trying to close them all the way, or trying to get them to go down from the top. Once i get the window to start going down, it is easy untill i have to close it fully.
    This is only on my front 2 windows, anything i can check or anything i can do to get some more power to each window? Well im at it, can i do anything to increase how well my door locks work?
    This is on a 1989 xj Laredo, full power doors
    My windows were always slow on my old cherokee as well. I used to just click the lock button 50 times before getting out. Usually did the trick. I never cared enough to look into the problem though, I chocked it up to old age.
      I am having the same problem. It's annoying as shit for some reason.
      Anyone know a fix?
      U.S. Army
        Bump: now my drivers side won't go down unless i push down from the top of the window
          motors might be shot, as for the doors, strip the panel off the door and plast the shit out of the parts with PB, unfroze both my doors that way.
          1992 xj Briarwood
          Welded front and rear
          13' LED roof lights
          Disco ball
          Truck nuts
          Spinners
            Am I missing something here?
            2 Broncos are better than 1
                my drivers side is working better now, it is really bad when it is cold out like early morning. My pass side get caught on something when it's fully down, so im gonna pull the panel tomorrow if it's not raining, and pb blast the shit out of it.
                  Its an 89 and it has power windows and locks? Lucky, my 96 is all manual. Did you do an upgrade or did it come all power?
                    Stock, my 1990, and my other 89 (first parts jeep) all had power, it's a Laredo
                      just lube everything and clean the connections to the window motor.
                        Well, got some snow last night/this morning, go out to the jeep, and the pass side window won't budge at all, and the drivers side window moves maybe 1/8th inch down, and won't budge.
