First locker- front or rear?
  • First locker- front or rear?
    Looking into locking the front or rear and then when more money appears, locking the remaining. Is it more beneficial to lock the rear or the front first?
    U.S. Army
    Rear IMO.
      rear fo shooo
      95XJ tons 3 link 36s 5:38s
      97 F-250HD 7.3 Turbo Diesel
      "Shut up and Wheel"
        I'm still using the dana 35 in the rear, so would I be better off using a front locker because its a stronger axle setup? (I would say lock the rear first, but since I have the dana 35, its not the best option) Any opinions on this?
          In your case i would lock the front. Putting any money into a dana 35 is a waste imo.
            x2
            2013 F150 fx4 (Tow Pig/DD)
            • 5.0 with the 3.73 option
            2003 TJ Rubicon
            • 4.0/42rle/np241or
            • 5.13's
            • 33” BFG KO2s
              I thought you could swap th d35 aussie into the 30? If that were the case you could lock the rear, than when you upgraded rear ends throw the 35 locker up front
                thats a great idea, and the aussie would be the way to go. BUT would my rear end "locked" make it to summertime?
                  if you baby it
                  Dizz dizz go sleep sleep
                  Driver 4677 FSM vehicle
                    I thought about suggesting that but I think it would be a waste of time doing anything with the 35. Why install a locker in the rear, blow it up and then put it in the front? I rather just lock the front.
                      Since yours is a 2000 it is a 29 spline 8.25. i would lock that first. however, you are running 35s now right? I would either get cro mo shafts for it or upgrade to a D44 or 8.8. unless you already have
                        I would upgrade the rear before locking the front or rear in your case....
                        Edit: Im a retard thought you had a d35
                        Id lock the rear first as i said earlier
                        "Shut up and Wheel"
                          That is correct.
                          Alright looks like Ill be replacing the shafts first before locking anything.
                          U.S. Army
                            do all 2000's have a 8.25??
                            4x4 Station Wagon...
                              Not all do. If it has ABS Brakes, it has a D35
                              U.S. Army
