welding on my truss
  • welding on my truss
    What are the main things i have to pay attention to when welding my truss onto my 44? On TNT's website i remember them saying "just locate it perpendicular to the ground and burn it home".
    But i also read another thread that a guy was talking about caster and pinion angle when locating all of his mounts. So what are the big things i don't want to fuck up when welding this thing?
    I was probably going to call up TNT and ask them before i do it but i might as well get some sis input.
    welding the truss on you just need to get it in the ballpark. all this will effect is the angle of the shock mounts and coil buckets really.
    i can eyeball my caster close enough, but you may want to get a cheap angle finder and set yours at 5-7 degrees.
    when you weld
    don't lay a mega bead at full power, or else you can trweak your housing
    give plenty of time to let that shit cool
      So basically eyeball my pinion angle and burn the truss on.
      And how do i adjust caster?
        control arms
        but if you arent 100% sure you can eyeball caster, don't eyeball it
        you will be stuck with a truss and axle housing you need to chop apart because your coils get spit out and shocks won't bolt to because of the angle
          Well if i adjust my control arm length, that will also effect my pinion angle correct? So basically i have to fall somewhere in the middle...
          I've read somewhere that people remove the outer ends of the axles and press/weld them back in with the correct caster/pinion setting?
            bump...
              yes people rotate the knuckles
              its not too big of an issue with a hp axle
              and caster>pinion angle
                gracias
