Problems with tire size over 35" on a Dana 44?
  • Problems with tire size over 35" on a Dana 44?
    Hi all. I have a Terraflex long arm kit. Running 3" lift with a 1.5" body lift. I am going to be installing some TNT steel fenders soon to give me the added room and flex. I hear that I should not run anything larger than a 35 (I have a TJ Rubicon) with the D44 as anything over 35 seems to be the cutoff when problems start. For those who are running larger tires, what are your experiences?
    I take it you are running stock axle shafts?
      Yes, currently. That is on the list however.
        if it were me i'd run 35's no bigger
          The outers are your problem, they are D30 outers. But I would def run some Alloys in the front, and keep ur stock axles as spares.
            this. i mean, plenty of us XJ guys lock dana 30s on 35s but i wouldnt do it unless I had alloy shafts. those rubicon axles are 30 spline shafts but just run Dana 30 outers. oh and they are the same 760x U-joint as a Dana 30 (as with all D44s). so your u joints will be your weak link IMO
