Fuel check valve
  • Fuel check valve
    Pretty sure mine is bad. i have to cycle the key on and off 2 or 3 times to get it to start normally. and after that it likes to bog down a bit until it clears up. Its either that or bad injectors but im going to start with the check valve. I did a quick google search and found that you can get inline ones? is this thing in the tank or no? where can i get one? do i have to replace the whole fuel pump? any help is appreciated. Im hoping Justin has a 1 page write-up for me
    its in the tank, part of the pump assembly.
    you can get inline ones. but its not as easy as a couple hose clamps and some rubber hose like pre 97's
