pitman arm
  • pitman arm
    My new steering uses 1 ton ends which puts me under the impression i won't be able to use my current pitman arm.
    Is there an easy way to bore out my current one to fit a 1 ton end?
    If not where would be cheap to get one, it has to be a 3" drop.
    Ream it?
      Originally posted by Bigbike View Post
      Ream it?
      x2.... all you need is a bigger hole.
        3" drop wut. why?
          My rusty's kit came with it, i'm assuming because of the drop trackbar bracket?
          Where/How can i get it reamed out
            With a "reamer"
              god i'm such a fucking noob
                1.5" taper per foot
                  stick to beer pong
                      your drag link and trackbar need to be parallel, thats all the matter. with the new steering youll need to lose the drop.
                        yea i know, which is why i thought the drop pitman was because my kit comes with a drop trackbar bracket at the uniframe end???
                        unless it isn't much of a drop...
                          yea thats why. youre running OTK steering? youll need the RE bracket and a straight trackbar
                            whuat!
                            Why do i need a straight trackbar?
                            And i should be able to keep my rusty's bracket, it's pretty much the same as the RE one.
                              you can use my reamer for the pitman arm if I knew who had it.
