removing engine (XJ)
  • removing engine (XJ)
    so I'm pretty sure I have everything unbolted the 4 bolts from the block to the bellhousing and all accessories and sensors are removed and engine mounts. Almost have it off the shoulders but didn't make it any farther, am I missing something or does it still just have to clear the output shaft? Was hoping to leave that shield attached to the bellhousing to keep the torque converter w/tranny
    doug
    1992 xj Briarwood
    Welded front and rear
    13' LED roof lights
    Disco ball
    Truck nuts
    Spinners
    Did you unbolt the torque converter from the flex plate?
      nope, didn't know I had to, never worked with an auto tranny before.... do I have to remove the flex plate? FSM instructions just say the engine to tranny bolts
      1992 xj Briarwood
      13' LED roof lights
      Disco ball
      Truck nuts
      Spinners
        well you have the bellhousing bolts and the flexplate bolts
          No pull the inspection cover and pull all the converter bolts. You will need to rotate the flex plate around to get them out.
            i took out the four bolts from the engine-tranny two lower and those bitch top ones, so I have to take the flexplate out with the engine?
            1992 xj Briarwood
            13' LED roof lights
            Disco ball
            Truck nuts
            Spinners
              ah ha, nice...good thing I gave up for the night instead of getting the pry bar
              1992 xj Briarwood
              13' LED roof lights
              Disco ball
              Truck nuts
              Spinners
                correct, it stays attached to the engine, the torque converter will stay on the transmission once you unbolt it. also make sure you got the 2 inverted torx bolts from way up top of bellhousing if it has them
                  theres 2 bolts that hold a shield on that ya gotta remove too. they are kinda hard to get at if you still have the manifolds attatched
                  no matter how many times i swap a tranny/engine i always forget about those 2
                    thanks guys, pics to come soon of the new toy, and in case anyone wants to know, you have to drill a ton of your own holes to get xj accessories to fit on a WJ block
                    1992 xj Briarwood
                    13' LED roof lights
                    Disco ball
                    Truck nuts
                    Spinners
