anybody on here ever do a fox 2.0 air shock setup in the rear of a jeep grand cherokee ZJ or can i consider myself one of the first people to try this mod. just completed the project.
Description:
Custom made 2 shock hoops from 1.5 inch round steel.
Custom made 4 brackets with gussets that were then welded to the frame
the shock hoops were then welded to the brackets as well as bolted in areas for added strength due to the added stress on this area.
the floor was obviously cut out in this entire area to fit the brackets, hoops, etc.
the wheel wells were also cut out where the shocks would be coming through with enough room forward and back, side to side where the shocks would move during flex.
custom paneling will then be made to again cover all the holes as best as possible while still having the shock come through and allowing for movement (coming this week)
tell me what you think.
thanks,
-Ryan
Description:
thanks,
-Ryan
