When redoing brake lines what do people here prefer, the stick you can get at NAPA or the coil of xx feet? I have to do the front pass side all the way from the master and pretty sure the other 2 along with the hard lines on the rear axle.
Brake lines
went to bradshaw jeep today... they can get me both front lines for $17 each and the rear for $40, i'll skip the rear since thats easy to do myself.
also, Mopar only makes NON abs front lines now, some how my 99 limited didn't come with ABS which is a good thing for me. i'll be going in tomorrow to pay for them and should be in monday. gonna be waaaaaaay easier than making up the line, also still look all professional and shit too
Originally posted by Burton58 View PostThe passenger line goes behind the harness on the firewall ...have fun
i'm gonna end up with the coil or cutting the OEM one in half then splicing back together in the middle... dammit
Originally posted by CumminsJeep View Postif you are going to get the coil (which i recommend), get the copper nickel line. So much easier to bend and will never ever ever rustwe use it all day at the shop and is so much easier to work with.
I just use coils and pull them through and bend as I go like snaking a wire.
Easiest way I found to do it.
I never tried the prebent stuff I never had the time to wait.RCrocs #123 Brown CJ-5
ive always just used the 25ft coils of the good coated stuff and threw fittings on/double flare. pretty easy to bend and lasts alot better then the pre-fitted length stuffup to 40% off parts from advance auto parts, buy online and pick up at store for free-click here!
HA! took all of 20min to fix the driver with the OEM one from jeep. i took off that coil that goes around it to prevent crap from being held against the line. all the XJs i see have nothing but dirt caked on there. i looked at the rear line... ya, looks like it's about to blow so i'll replace that tomorrow with some of the 25ft roll i picked up.
