ok so ive owned this thing for like 5 years, it used to be the plow truck but it hadnt been used in 3 years. so last spring i decided to dig it out of the weeds, put some bald 31s on it and use it for trail cutting at my house. ive beat on it for the past year and the renix 4.0 and pukegoat 5spd are still holding up fine.. well a month ago i broke both front shafts at the same time..
so with rausch creek opening 1200 acres and my love for trail cutting i decided to make it a little bit more rock reliable. so i pulled an 8.8 with 4.10s at the jy and at the same time i pulled the gears out of a 4cyl comanche. i installed the gears in a hp non disco 30 i already had with 297 shafts.
then i started bulding the 8.8.. i tig welded the spider gears up first and then
i bent up some tube for a diff guard and welded it to the stock cover after i plated the lower lip
then i built a removable pinion guard for it
and fabbed my own u bolt eliminator spring perches that use 5/8" bolts and have integrated bump stop pads
so once my 8.8 was ready to go in i decided that i didnt want to put it back in sua because of the crazy loss of clearance.. but my leaf springs were in awesome condition and would have given me like 8" of lift if i put them spring over.. i decided to inboard my leaf springs to the inside of the unibody rails and up about 5" i fabbed new spring pockets on some stiffeners and welded them up
next i built new shackle boxes and set them up using some 1.5 shackles to get a nice nice shackle angle
while i was working on the back half i recessed an xj gas tank down in the floor in the front of the bed to get it up out of the rocks and protected
right now it has beat 3" coils in the front and its sitting level
i got some 33" dunlop mud rovers with like 75% tread in trade for a gas tank skid i built for some one
its a work in progress and needs to be finished for my trip to rc the weekend of may 1st.. i have a lot of work to do still
fab front diff guard
fab front stiffeners and bumper
fab new crossmember and flat belly
fab boatsides
fab rear bumper
fab rear shock mounts (upper and lower)
install dual brake booster and zj prop valve and all new brake lines and hoses
install front shocks
install new u-joints
wire up electric fan to a switch
install renix sending unit into tank (so my gas guage works)
figure out exhaust
and a bunch of other random junk
ill keep updating as it comes along
fab boatsides
fab rear bumper
figure out exhaust
